captainhook
- Southern Maryland
- Limited
After a not-so-great launch due to a lot of wind and current and not getting out until about 2 and a half hours later than we wanted to, we had a nice ride around the river yesterday. The jellyfish were out in full force so I first went south towards the Chesapeake Bay but the chop was getting to be a bit much for the kids, so I turned around and did some sight seeing up north while two of them slept. As I'm turning around to head back towards the launch, I see a couple of guys off to the side of the river a bit with an oar in the water. Now it is not an uncommon sight at all around here to see things like this with people fishing and crabbing, so I continued on. A couple of minutes later, I thought to myself, that wasn't a fishing boat so obviously they weren't crabbing and typically you don't use an oar, let's turn around and make sure they were okay. I wouldn't have been able to sleep last night if I didn't stop and they were taking on water or something. As I get closer, one guy is still rowing and the other one starts waving at me. Not a "hi!" wave, a "I need some help" wave. Turns out they did have engine problems and needed a tow and had to borrow one of my kids' buckets to bail water.
So I get out the two dock lines and tie them together, then realize they are too thick to fit around the stern connector, but fortunately I had a ski rope that has a really thick side to it. I tied all of this together, and connected it to the stern, then fired up the engines. The other boater tied to the front of his boat, and the rope was in the water. Due to the current and wind, our boats kept getting flipped around and as I'm watching the rope in the water before I hit the throttles, I thought, "hmm, that rope looks really deep down there" so I quickly cut off both engines. I went back to the swim platform and sure enough, one of the ropes is wrapped around the drive shaft and wedged into the impeller. I thought for sure I was going to have to cut the rope, which would've ended my chances of towing anyone safely let alone our day on the water, but after twenty minutes and some use of the ingenious clean out plugs (you listening @chess? Get those fixed ASAP
), I was able to get the rope free and tow them in safely. The other boater said he had a couple of jet skis and was thoroughly impressed as he had no idea it was a jet boat.
That was my third time using the clean out plugs, and first time sucking up a rope. When I was a kid, a buddy of mine sucked up an anchor rope with his Waverunner VXR and it took what seemed like hours to cut it free. Of course we had to flip the ski over and sit on the hull upside down to get the rope out. I was really glad to have the clean out plugs or that would've ended our day on the water too.
