Addicted
- Lake Stevns, WA
- Limited S
I am currently installing REV 10's on the forward tube of my tower. I have my 2 holes drilled in the top of the tower, as well as one drilled down on the Starboard side, just above where the tower mounts to the hull. I am struggling to get a pull string run through the tube. I have used the fishing line and shop vac trick, with no luck. I have plenty of vacuum coming through the tube, so there is definitely a path, but I cannot get the fishing line to pass all the way through.
Approximately a foot above the bottom of the tube, there is a welded splice in the tube. I sent a fish tape up from the bottom, and get stuck at that location, so I am assuming that is where my issue lies.
Anyone else have success running through the forward tube of a forward sweeping tower? I would really like to avoid drilling two more holes in the tower, to exit then re-enter around that splice joint (I am assuming there is a sleeve in there, maybe a solid plug?).
