I towed my 2017 212 Limited S for a couple years with a 2007 SR5 4Runner 4x4 with a v6. It did absolutely fine. I will say I never towed on an interstate at interstate speeds. Mostly 2 lane, 55mph roads. It did absolutely fine. Of course the surge brakes on the trailer help the situation.Wanted to hear about any towing experience with a 4Runner SR5 towing a 21ft? Any advice?
I rented a 4Runner TRD last summer from our local Toyota dealer for a vacation. Towed our 212 LTD S 4 hours each direction and much of this was freeway driving. It held speed at 75 with no issues at all. I would not hesitate to use it again. I was comfortable with it's braking capabilities and didn't feel any unusual trailer sway.Wanted to hear about any towing experience with a 4Runner SR5 towing a 21ft? Any advice?
Don't feel bad about that mileage. My Land Cruiser gets about 8 round trip from Mesa to Roosevelt with the 5.7 V8.What year 4Runner? I have a 2017 4runner SR5 4x4, 3in lift, 285 tires, Firestone rear airbags, and a AR195. I wouldn't suggest anything over a 19ft boat unless your lake is within a few minutes away. I believe with a 21 foot you’ll be at max capacity weight (5000 lbs), I’m sure I’m pushing 4000 lbs right now. I would also suggest keeping it out of OD (manual 4th gear only). My 4Runner does ok on the straights but struggles when going up a decent grade. I have to lower speed to around 45 when going up hill for an extended amount of time. For this reason I just installed a transmission cooler because I know the trans temp has to be on the high side especially out here in Arizona at over 100 degrees. Fuel mileage is around 9mpg when towing which I’m guessing is not so great. Procharger just came out with their bolt on supercharger ($6k)which should help the situation with power but you would be stretching the 4runners capabilities. On a side note the new 2021 Tahoe looks pretty nice. 8500 lbs towing and a diesel option in the near future.
View attachment 126055View attachment 126054
BTW, I think I had Valentines day dinner/picnic this year in that spot you're parked in. Up the hill at Saguaro right?What year 4Runner? I have a 2017 4runner SR5 4x4, 3in lift, 285 tires, Firestone rear airbags, and a AR195. I wouldn't suggest anything over a 19ft boat unless your lake is within a few minutes away. I believe with a 21 foot you’ll be at max capacity weight (5000 lbs), I’m sure I’m pushing 4000 lbs right now. I would also suggest keeping it out of OD (manual 4th gear only). My 4Runner does ok on the straights but struggles when going up a decent grade. I have to lower speed to around 45 when going up hill for an extended amount of time. For this reason I just installed a transmission cooler because I know the trans temp has to be on the high side especially out here in Arizona at over 100 degrees. Fuel mileage is around 9mpg when towing which I’m guessing is not so great. Procharger just came out with their bolt on supercharger ($6k)which should help the situation with power but you would be stretching the 4runners capabilities. On a side note the new 2021 Tahoe looks pretty nice. 8500 lbs towing and a diesel option in the near future.
well its pretty much the same as the tacoma. I was told I shouldn't tow my 24' and that it wasn't capable but it tows and pulls from the ramp with no problem. The trailer has its own brakes so that is a non issue I am very glad I didn't try to upgradeWanted to hear about any towing experience with a 4Runner SR5 towing a 21ft? Any advice?
Yeah saguaro. Haha yeah for sure.BTW, I think I had Valentines day dinner/picnic this year in that spot you're parked in. Up the hill at Saguaro right?
In hindsight going to a restaurant once more before covid might have been a better idea...
