Marvin willis
- Morehead city nc
I’ve got a 08 ultra 250x 150 hrs. (Motor replaced at 106 hrs)It seems to always show the low battery voltage when I first start it (12.5volts when tested). Cranks right up. Here’s my issue. Runs perfect 99% of the time then randomly drops in power. Up down up down. Has cut off on others but not me. After u restart it, it will run fine again for a while and will start to miss again. Plugs are new. Happens at all gas levels. Sometimes it idles at different levels. But most of the time runs perfect. I did try to see how fast it would go one time and the speedometer went crazy after 50. Speedo Went down to 30 and bounced all over even though I was going way faster. Slight vibration after 65+ if it wasn’t missing.
