jamesk
- PA
- SX
Can someone tell me where either the tow shut off valve gets installed or if you are just clamping the hose in a tow situation...on a TR-1 engine where you clamp the hose?
Also if you have to get towed with a twin engine boat....you shut off the flow on the engine that is not running and what do you do with the engine that is running (just let it idle?)
Thanks!
Thanks!
