MFalcao
Hi all,
After hydro locking the starboard engine (my fault, bought the boat with 150 hours last year, starting the season made the mistake of wrong sequencing the dry start), “clean” the water, flush 2x the engine and running on the lake for 4 to 5 hours, rod broken while 6k rpm’s and crankshaft case blow up. we sent it to a Yamaha dealer (Elite) and bottom part of the engine replace by Yamaha parts, went for a test and a lot of white(blue) smoke out of the engine. Pull the boat out of the water and hull was black with burned oil ( see pictures) Took it back to the dealer and after re-opening the engine notice that a guide for the time chain was broken and also replaced the valves of the 3rd cylinder (the one with the broken rod), back in the water could get more than 7400 rpm’s (port side runs 7800 easy). Dealer spend a week with the boat testing before releasing and that 400 rpm wouldn’t bother me as he couldn’t find out why… spend 2 weeks with the boat and after 12 hours (spent 4 hours easy the engine in…) smokes back again and reves won’t pass 6200 rpm. Because of the smoke notice oil level went down a lot… below minimum. Hull has the same black stains. Rings are new, rods, pistons,… all new from Yamaha. What else could it be? Would bad valves cause that? Engine doesn’t start easy as the pot one. But it starts and low revs don’t see smokes… after 5 to 6k smokes starts and boogs after 6k… also add pictures of the engine when first stop after hydro lock… nasty hole on the crankcase.
