IMO, you're gonna wanna take a ride out to check out your trailer for a few "fitting" items before you hook up to your boat, if you don't have anything set up to tow yet.
What type of electrical plug do you have, a "Flat 4/5" or a round socket (7-pin)? You need to match up the electrical hookup from the trailer to the vehicle. If you don't have the proper one, you'll need an adapter.
Once you have an electrical hookup, you also need a hitch and a ball, if you don't already have one. I got an adjustable hitch because I have 2 different vehicles at different heights, and I wanted to be able to tow my boat with whatever was available - you don't need this, but you'll want a hitch with the proper drop (or rise, if you need to flip it like
@BigAbe75 mentioned). The hitch coupler should be level, and you simply measure from that point to the middle of your hitch socket for the proper drop/rise. Head over to Walmart and buy the hitch that corresponds to your measurements, and buy the proper size ball for your trailer while you're there.
You may want/need a magnet for the reverse key, that's gonna be a personal choice, and in my view, you won't know if you want/need it until you've towed a few times. I've got one, and I've used it a few times, but I don't find it to be a necessity, YMMV.
Hooking up your trailer should be reasonably close to these steps:
Put the hitch coupler over the ball and lower the jack until the coupler rests on the ball and the jack wheel is off the ground. Swing the jack up, secure it to the trailer, and close the latch.
Put the locking pin through the latch/coupler
Take the right trailer chain and cross it underneath the coupler, and hook it up on the left side of your vehicle. If the chain hits the ground, twist it until it no longer touches the ground, then hook it up to the vehicle. Do the same with the other chain - left trailer chain under the coupler, hook it up to the right side.
Plug the electrical connector into the vehicle.
Have someone sit in the car and operate all the lights - running lights, left turn signal, right turn signal, hazards, brake lights.
If you've chocked the wheels, remove them and stow them in the car/boat.
Put your transom straps on and tighten them up
Tighten the bow roller strap, and make sure the bow's safety chain is hooked up
