4x15mph
- Downingtown, PA
I have a 2019 OEM galvanized trailer with surge brakes. I disconnected the wiring harness to the truck before backing up and putting the boat in the water since I didn't want the wiring to potentially short when it hit the water. I then realized that without that connected, and without the emergency key attached, I should not have been able to back up since the brakes should have actuated. Is that right? Is it possible I was backing up down hill (ramp) so that is why they didn't engage???
I know that the brakes worked on a flat surface since when I backed up without the wiring attached, the trailer brakes kept me from moving.
Thoughts on above?
Thoughts on above?
