Yambers
Jetboaters Commander
- Indianapolis, IN
- Limited S
So I was wiping down the boat and I couldnt stop staring at the water marks on the painted shorelander trailer. Then I remembered a trick I always used on my harley with a black crinkle painted engine, and I used it on the vehicle frames and suspension parts.
WD-40
I just spray on a small amount, wipe the residual off with a rag, and the frame looks new. Not only does it look new, but the WD-40 protects it from water damage, hence the WD (water displacement). I guess I could just spray on and then drive to the lake. Residual would run off.
Not sure if anyone else uses this trick, but I had a 1996 chevy truck I recently sold and the frame looked like new. Works on metal and plastic. I had coated it since it was new.
Anyone else doing this? Or something similar?
WD-40
