SierraWhiskey
- Limited S
I'm looking for some guidance and am hoping someone could answer a question. I took delivery today of a new 2016 Yamaha 242 Limited-S. My tow vehicle is a 2015 GMC Yukon with HD tow package. The vehicle has no issue towing the weight. I also purchased a trailer hitch ball mount with 2 inch ball and 2 inch drop because it had a 6000 pound capacity. At the dealer, we hooked up the boat with no problem, however when I arrived home with the boat the front jack wheel fully extended barely reached over the top of the ball. I had to really crank on it to get it to raise high enough to get it off. The vehicle and trailer were level and I'm thinking it must not have been at the dealer because there was no issue there. Anyway, I have another ball mount that has a 3 1/4" drop that would work better, however the towing capacity is only 5000. From what I can find, it appears only the 2" drop ball mounts have a 6000 lb capacity and I'm not sure if the 5000 is enough. I know the boat full of fuel will be over the 5000 lbs, but not sure what the safety factor is. Advice? By the way, my Yukon has an auto leveling feature that I cannot turn off, which probably jacked up my truck when we hooked up the trailer the first time.
