MN190
- SX
Hello all,
New to the forum.
Have a question about the 3 light Identification Light Bar on the rear of the trailer.
It got smashed up at the shop while being winterized. I was sent a replacement. It’s a LED type and the trailer had a non-LED type.
I figured no big deal and the LED would be an upgrade.
The new LED only has 1 wire. What should I do with the other wire.
I just spliced the wire and twisted them together to test before actually making a secure connection. I could not get it to work at all and all my running lights are no longer working.
The only light that works is my rear right turn signal and brake light.
The Left brake light needs to be replaced as it is corroded out.
What is the proper way to hook the new 3 LED light bar or should I get an OEM type?
Thanks
New to the forum.
Thanks
