Ronnie
- SF Bay Area
- Limited S
So I just dealt with a trailer problem and now want to develop and install a tool box to my boat’s trailer. So far I’ve heard water intrusion has been a problem that has not yet been resolved.
I plan to mount the tool box on the front of the trailer frame, opposite the trailer jack.
My friend suggested that I look for 7 / 7.5 gallon storage containers similar to the plastic 55 gallon barrels used for commercial purposes. He is a welder and I’m confident that if he says he can fabricate a mount and locking mechanism he can do so. Here are pics of what I’ve seen so far, I also included a few mounts for visual purposes. If I got with two 7 gallon containers I would probably mount them vertically. If I go it’s a single container lager than 10 gallons I will likely mount it horizontally. One hint I was told to consider is the possibility that the air tight container will be so buoyant that it could lift the tail of my tow vehicle when launching or recovering.
A I haven’t purchased anything yet, what do you guys think? Which containers, if anything pictured, should I use? What would you use? Should I be concerned about it lifting the rear end of the tow vehicle? I don’t think so since only a small part of the container will contact the water, at least the way I’m currently envisioning it.
