chesbay007
- Annapolis, MD / Chesapeake Bay
I use my boat in the Chesapeake Bay and occasionally the Ocean. Often the boat is left in the water for 1-2 weeks at a time. so, I pulled the pumps after 10 years of neglect this weekend. And it appears that I have 10 years of problems. Both transom plates have deteriorated and need to be replaced. (Has anyone ever had this problem or replaced them). Both pump housing have swollen and started to rub the impellers. Has any used used the stainless steel after market pump housing from Riva? I could only find the OEM & Riva Stainless housings. Lastly, I wanted to get everyone's opinion on the impellers. They appear to be in great condition besides a little rubbing on the housing. Should I have them reconditioned or start looking for aftermarket props. If so, what do you recommend. The good news is that both bearings look great!
2005 Yahama AR230
2005 Yahama AR230
