Trim tab install help!!!!
LakeTravisBear
Austin, TX
Need help!!! in middle of trying to install trim tabs on 2019 AR190 with mechanic. He is telling me he is concerned on how to ge the wires through the rear bulk head on the back of the driver side? Any help would be appreciated.
Also need help, these look way to big but lector tabs swears it’s the correct size, the only flat part to mount the tab hinge is by the pump under the scupper but don’t they need to go further out?
Follow the existing wires
Ideally you'd like to put the here. Not sure if they'll fit though as the actuator may be too steep of an angle. But, that's where I'd put them as I did on my 192. They need to be as far out to get the best action from them.
The boat has a passthrough for the steering and reverse cables you can use those to get the wires into the engine compartment and to the helm
Any update on how this worked out for you?
