FSH 210 Sport
- Tranquility Base
- FSH Sport
A friend of mine told me about this device today. I had told him about wanting to be able to charge the trolling motor battery bank while cruising on the main propulsion.
I called and talked with the tech support and explained the limitations of the OEM charging system and the tech told me that this device will only charge as long as the system is producing 13 volts or more, and as such will keep from damaging the OEM stators.
Yandina Trollbridge36 Battery Combiner
Allow Charging of 36 Volt Trolling Batteries from Single-Output 12 Volt Source, Rated for 12 Volt Alternators up to 100 Amps, Rated for 36 Volt Trolling Motors up to 85 Amps
www.defender.com
