Floridaman79
- Brevard County Florida
- FSH Deluxe
Question for you guys. So I have 3 lifepo4 batteries on order for a trolling motor installation. I naturally assumed that I would run a ground wire from the negative of the 36v bank to the negative of the house and start batteries, therefore holding the ground at the same electrical potential throughout the boat. When reading the installation manual of the motorguide xi5 manual, it says to only connect a common ground to a 12v trolling motor system and not on a 24 or 36 volt bank. Does anyone know the reason behind this? The only thing that I could think of is if the grounds are not connected, the relative potential could be reduced during a galvanic event like a pull down resistor whereas if the grounds were connected the voltage potential would be fixed at 36v. Does anyone have any thoughts on the common ground between different voltage banks?
