Trolling Motor Power Receptacle
John_D
Sebastian, FL
FSH Deluxe
Want to put a trolling motor on my new 195 FSH when I get it but I don't see receptacle for it. I do see the the trolling motor plate??? Has anyone installed one and if so any suggestions would be appreciated Thanks
Mine is installed on the vertical surface above the raised deck next to the trolling motor mount.
No - I had a pro do the all of the electronics (see signature). The part he used for the plug was:
Battery Tender
027-0004-BK Trolling Motor Plug/Socket
24V
X2 Power Battery
SLI31AGMDPM 12v Group 31 AGM Dual
Good morning,
I installed a Minn Kota Riptide Terrova with a 60" shaft. I'm powering it with 24v (2 Optima Bluetop D34M Batteries). I used a Minn Kota MKR-26 Trolling Motor Plug Receptacle 1865129 MKR-26 Trolling Motor Plug and Receptacle. I installed a NOCO Genius onboard charging system. I wired my system using 6 gauge marine cable. Note: if you're going with a 24v system it is recommended you use a 40 amp breaker. If you have any questions please feel free to contact me. See attached photos. Help this helps.
20201210_135021981_iOS.jpg20201210_135059266_iOS.jpg20201210_135119417_iOS.jpg20201210_135141569_iOS.jpg20201210_135215865_iOS.jpg20201210_135237987_iOS.jpg20201210_135248061_iOS.jpg
