muleror
- SX
Hello,
I have a 2017 SX190. I put my boat on the water for the first time this year this past Saturday. When turning on the boat I got the "Check Engine" warning. I immediately acknowledge the alarm and small caps letters on the lower left appeared "AL". This warning kept popping up and beeping like crazy every 4-5 minutes while driving. I went to the engine Diag menu and the Troubleshooting Code is "Normal (SPN 0)". The boat runs perfectly with no issues what so ever.
I have done the following tips recommended by folks who have ran into this issue before:
- reset the battery by disconnecting and reconnecting back.
- start and stop the engine 5 consecutive times.
I was told by doing some of those the warning will go away.
None of the above have worked.
Also, I spoke to the local dealer and they said that may be a Service reset. But they will not do it as they did not perform the last tuneup/service.
So, i am reaching out to see if anyone has a clue or has ran into this code before.
I would appreciate any help on this. THANK!!
Rey
Rey
