JBehrens
Jetboaters Commander
- Huntington Beach, Ca
- SX
Hi all, just got back from Lake Powell and was experiencing a strange issue with the boat that hasn't been seen before. When underway, the engine would randomly get boughed down (almost like it was starving for gas or miss-firing), loosing anywhere from 200rpm to 750rpm for about a second then returning to normal. It would sometimes be repeated for say 25-30 sec. This event was completely random, boat would run for say 15-20 min straight with no issues then have ~5 minutes of the random power loss events. I'm really not sure what would have caused the issue.
Things to note:
Troubleshooting Steps Attempted:
So what could I check next/what might this be? Bad gas, broken fuel injector? Any help or ideas are appreciated. Thanks!
Things to note:
- High altitude impeller installed for Powell
- First tank of gas was clear 87 (no ethanol) normally the boat is filled with regular 87 up to E10
- RidSteady installed on boat
- No engine error codes
- Disconnect RideSteady (no change)
- Check Spark plugs (all looked normal, nothing dirty)
- Checked battery connections
