captras
- Lake Livingston, Texas
- 242 Limited S E-Series
Opinions regarding adding the second steering tie rod to the new Yamaha twins with the articulating keel. Is it really needed, or is it one more thing to spend money on? If it is necessary, why is it not standard from the factory? Can you just buy the tie rod....used to be available on CJ web page, but cant find it anymore? Lastly, if you were to install the TV, does Jetboat Pilot make a set of twin TV with a notch for the additional tie rod on the right nozzle?
