jcsmith77
- Harrisonville, MO
We have been trying to wake surf this year and I wanted to get your guys opinion of my setup and my experience to see what i am doing wrong and what i might be able to improve.
I have 1 400# bag under the starboard rear seat shoved back into the void next to the engine so i know it doesn't get completely full. I have its match in the same spot on the port side and then an 800# filling the rest of the underseat space around the battery. I fill them until they start pushing up the cup holders. I have another 400 lb bag that i have put on the swim deck or the port seat depending on how many are with us.
So the wave that it creates seems to be very close to the boat. I(6'4" 225lbs) can go ropeless but i am literally right behind the boat to keep enough push and we seem to be going way to fast (14 mph by the factory gauge). I seem to be able to come down the wake, i can hit the boat with the nose of the board if i want but i flare up into the wash, slow down and do that over and over. Occasionally i can be a couple feet back, but the sweet spot is much smaller and harder to maintain.
We pull out of the water and it seems like we have nothing but wash until we get up a little faster and then we settle back into the 14 mph range. This past weekend I filled the underseat bags and then put the extra 400 on the deck and tied it off, but with my friends sitting in the back of the boat, at full throttle we couldn't really build a wave. My buddy, probably 200 lbs had to go sit in the front and then a smoother face would form. This is with the engines at full throttle. Then once its there we can back off the throttles a little.
So if you read all that, what am I doing wrong? still not enough ballast? improper placement? why do I have to go so fast to get a wave when everyone else says 10 mph?
