mrcleanr6
Jetboaters Commander
- new jersey
- 275SD
do any of you know if there is an sd card in the new 12.3" displays? i have seen other threads where it looks like a rubber cap on the back of the display that you can remove and the sd card is in there. i have my display mounted in that floating pod. i took the 4 machine screws out of the back to get access to the display and i didnt really see anything there. i could still dig into it more since there was some mounting brackets on there that i can remove but only thing i saw was a small screw in cap that you need a tiny bi-pin spanner wrench to unscrew but even that looks too small to fit a micro sd card. the head was smaller than a dime. its possible its under that but looks too small to me. any of you guys with a newer boat tried this?
