BrandonC_OK
- Claremore, OK
I'm planning to pull the boat out this weekend and make our first trip to the lake. Over the winter I bought some used carpet off of Facebook marketplace. It was in pretty good shape and it was only $150. Unfortunately, many of the snap caps on the carpet don't line up with sockets in the floor. Anyone with experience know the best way to address this?
I'm guessing there is some variation in the install from boat to boat and the carpet has likely shrunk a little (the largest piece is 1.5" too narrow from side to side).
My current plan is to remove the sockets and relocate as needed. I'll fill the old holes with epoxy and may or may not add gelcoat.
Other projects - The depth gage has never worked so I have a replacement on order that I hope to install this weekend. My old one is transom mount so that is what I'll replace it with. I also plan to see if the apparent adjustment for the speedometer allows me to calibrate it (see previous post) and also try to calibrate the fuel gage sending unit. My previous attempts at the latter just made it worse I'm going to fill to 1/2 tank and calibrate to that since calibrating to FULL didn't work so well. Also replacing the 10 year old trailer tires that I noticed had cracks.
Thanks, B
Thanks, B
