peter upfield
- LS
I need information on what the actual oil ratio or consumption curve is for a 2001 LX2000. I'm going to build an electronic engine control system and want it to include a metering pump for the oil. I'll need the rpm : oil use curve and I'd rather not have to figure it out myself.
If anyone is interested, the system will start as a fly-by-wire cruise control referenced to synchronized engine rpm or GPS indicated speed. Maybe later I'll add steering and directional control. With the new reverse control enhancements from Thrust Vector, I'm planning on an auto docking sequence by controlling the port and starboard engines and nozzles independently.
