tdonoughue
- The Woodlands, TX 77381
None of this happened, because I don't have the pics yet... Sorry, we were rushed. They are coming.
Replaced the bow stop roller on the trailer. One bolt job. Couldn't be easier. Except if I had the right tools. Two deep socket 19mm would have been ideal. Now hopefully the roller won't be scuffing my boat any longer.
Rewired the amp on wire to the antenna wire of the receiver. I had it just to the receiver positive previously, which was pretty messy. Now it stays off until I turn on the receiver.
Installed new fire extinguisher. This is embarrassing. While rewireing, it occurred to me that the little Kidde fire extinguisher I had mounted to the port side of the opening to the helm in the compartment had not been checked since installation. However, while examining the thing, there was no gauge and nothing evident for how to check it. Idiot that I was, I read the directions. They said to push the white button. If it pops back, then it is fine and if not replace it.
The only white button, as it turns out, is the activating switch for the extinguisher... Poof. Cough, cough, cough...
Installed 4 1.5" rod holders from Academy in the head compartment aft wall, positioned to hold the 2 table legs.
Installed two Blue Sea terminal fuse holders (dual) on the two batteries. If only USPS had not messed up shipping the actual fuses from Amazon...
Installed the Blue Sea dual circuit switch. Install of the ACR that came with the Add A Battery is pending the fuses... And for me to finish making the two wires to connect it, but no point to that until the fuses are here.
Lots of little things. Very satisfying to have some of this little stuff done.
