Does anyone have Thrust and lateral vectors?
How do they work for your boat ?
I do have the cobra vectors on my boat now
Thoughts ??
Are thrust vectors a good idea for new boaters? I have a Yamaha FSH195 Sport. Haven’t gotten it on the water yet!
I’ve just learned the FSH 195 comes with vectors
Your probably confusing the articulating keel for aftermarket steering fins.I’ve just learned the FSH 195 comes with vectors
Ah yes. They did call it a keel in a video I saw. With that said, are vectors still necessary? Sounded like maneuverability with the keel was goodYour probably confusing the articulating keel for aftermarket steering fins.
Learn to drive the boat as is first. Then if you want better control do your research and go with the solution that fits your needs. Cobra's are made of aluminum and provide the most control at slow speed and high speeds. Thrust Vectors are plastic and only provide more control at slow speeds.Ah yes. They did call it a keel in a video I saw. With that said, are vectors still necessary? Sounded like maneuverability with the keel was good
Thank you!Learn to drive the boat as is first. Then if you want better control do your research and go with the solution that fits your needs. Cobra's are made of aluminum and provide the most control at slow speed and high speeds. Thrust Vectors are plastic and only provide more control at slow speeds.
