- Corinth, TX (DFW)
94 Ford f350
I have a 7 round with a 4 and 5 flat spliced in.
Last month every thing worked great using both my boat trailer and utility trailer.
This weekend I did my good deed and pulled the boy scout trailer to camp. It had an issue of the left turn/stop light not working on other peoples vehicles. I decided to try to trouble shoot it.
I swear the first thing I did with the multi meter was confirm I had power on all the terminals at the truck.
I then took the light off on the trailer looking for any obvious issues.
Not seeing any I was going to run a bypass wire straight from the truck side to the light to try to confirm the problem was somewhere in the trailer wiring.
I looped the end of the wire around the left turn terminal on the truck side of the 7 pin and ran it back to the trailer but got nothing.
Confused I got the multimeter back out and now I have no power going to the left turn terminal on the truck side on any of the plugs but the truck it self doesn't have any issue, all the lights work.
I could understand if I blew a fuse but wouldn't it have blown and my truck lights wouldn't work or the all other terminals on the 7 pin?
I don't think anything special has been done to the truck but would it be common for each terminal on the hitch to have it's own fuse?
Just looking for some ideas before I have to have a bunch of dirt fall in my face trying to undo all the connections under the bumper.
