Versiplug or Flow-Rite drain plugs?
I have the Versiplug. I have had not issues with it but I do not wet slip
Thank you, as you can see I won’t be wet slipping either
I had it out once but haven’t check if there is any water down there ran the bilge and nothing came out.
I really like the fact that any water that does enter through the anchor locker drain, clean out tray, ect., that cannot be picked up by the factory bilge pump, is sucked out the Versiplug while I’m underway. Now there is never any water pouring out the rear of the boat while I am doing the post trip at the ramp.
The Versiplug looks pretty interesting. Has anyone had any issues with it? I think I may try it out.
Seems like it might stick out too far for the articulating keel, doesn't it?
I dunno. Would like to know if anyone has one with an AK.
It would be great so I don't have to go find the plyers sometimes when it can't unscrew the stock plug sometimes with my hands.
Had mine for two summers and no issues. I actually never think about a drain plug anymore. I don’t know if that’s a good thing or not. :)
I had something like versiplug and it failed at the fifth use.
It was this one
Cannot recommend.
