VHF External Speaker-Opinions Needed
AndyD
Jetboaters Commander
Wake Forest, NC
242 Limited S E-Series
So after our first group outing with our new VHF radio I quickly learned that when at any decent speed you can't hear shit from the stock speaker. So in preparation for a future Bimini trip we decided to purchase this external speaker.
https://www.amazon.com/gp/aw/d/B003...f_4?ie=UTF8&psc=1&refRID=7A4S8PA7W587CTR32GCE
Now my question is, based off of the increased volume from the external speaker where would be the optimal mounting location? My initial gut is to mount it under the dash next to the radio but I don't like the look or the placement. It does have the option for a flush mount and I was thinking about flush mounting it on the side of the dash for a cleaner look but not sure if I would get the benefit from the captains chair. On the flip side though it will point right towards my co-captain, and hey let's be honest, her hearing is much better than mine. Thoughts from others who have external speakers? Will I be able to hear it clearly from the captains chair when mounted on the side?
I would not mount it to the side. Someone is likely to knock it off. Especially in rough water.
Mine is mounted on the dash
I'm not worried about someone knocking it off. If I mount to the side it would be a recessed flush mount similar to the radio speakers so it wouldn't stick out more than 1/2" or so. Just wondering if it would direct the sound the wrong direction where i still wouldn't hear it.
Where u r holding it is a shin getter! Ask me how i know... on my boat i had a small flat area under the steering wheel. But my speaker is small... i wish i had purchased a larger one.
Unrelated, but where did you mount your antenna?
I mounted it on the main tower frame, you can see it in this photo. I had to rig up a couple of different mounts to get it to fit right but I'm happy with the end result. A 4' antenna reaches about 1' higher than the highest point on the bimini frame.
Thanks, that looks nice. Planning my winter shopping plans :)
if it is going to be flush why not put it next VHF?? to the right I think you should be able to find a place
Finally got around to hooking up my external speaker. Wow! What a difference it makes. My biggest concern was trying to find a good location to flush mount it to try and keep it looking as clean as possible. Settled on a great spot right under the throttles. DC8FA54C-0469-4413-A93E-30DB940B04CB.jpeg
That's beautiful! I was going to suggest to you to find someplace on the driver's right side to mount it, and preferably higher up than the first two spots you showed. I was looking for a spot myself and from experience, I know they have to be aimed at you and as high up as you can get them. I think you found a great spot. Let us know how well it works for you.
How did you make that mount for the antenna?
Good looking spot for it @AndyD . I was pondering how to put it up on the tower....problem with this model is I'd need to change the mount to something that would work with the tower frame....
Maybe I'll just put it where you did....but I fear my fume detector and USB charge ports are already in that location...hard to tell from this pick....
20170225_164354-jpg.51951
Yeah, I put it smack dead center of where the warning label was so it would creep into your existing add ons.
Finally got around to hooking up my external speaker. Wow! What a difference it makes. My biggest concern was trying to find a good location to flush mount it to try and keep it looking as clean as possible. Settled on a great spot right under the throttles. View attachment 69083
That looks really nice. I can't hear my VHF at all while underway, though I primarily use it while idling up to a bridge or something. Any issues hearing it underway now?
So are you happy with the location in terms of sound output? Considering doing this....
Definitely much better than the stock speaker. I haven’t gotten a real solid test this year since installing it short of the weather broadcast while messing with it in the driveway. I’ll be out next weekend in the boat and will give it its full test at 30mph. But I do feel very optimistic, anything is better than stock.
I haven’t gotten a good test with it yet but will know more for sure next weekend. I’m very optimistic just based off of playing with it in the driveway.
Did a field test today with the external speaker location. MUCH improved from the stock internal one and the location of the external seems to be in a good spot. I was able to clearly hear at 25mph.
Awesome, thanks for the update!
