Chumash
I finally got my boat out after a 3 year layoff from boating. I have a 2008 ar230 ho, and changed the oil, plugs and water / fuel separator filters. Lubed the bearings and drained the old fuel. I also installed Cobra Venom fins.The boat ran great, pulling a tube and wakeboarders. On the second day, I sucked up a rope in the right pump, but was easily cleared through the clean out plug. On the third day, after a full day on the lake, as I was heading in to the dock, I had a vibration on the right side when accelerating past 4-5K rpm. The vibration got worse the higher the rpm. I was able to get back in easy enough at low rpm. I pulled the boat out of the water, and when revving up to clear water from the exhauSt, there was no vibration. The reverse gates seem to be working properly, and the fins are working correctly. I am assuming that this is something in the pump area, and am planning on pulling the pump and inspecting it.
What would I be looking for besides obvious defects or damage? Could this be caused by a bad bearing, and if so how do you determine it is bad? Any other ideas would be welcome. I am hoping it is just a piece of rope stuck somewhere it doesn't belong. But as the boat ran fine after the rope incident, that may be just wishful thinking. Thanks for any help.
Ted
Ted
