Nickoxios
- Scarab
- 195 ID
I’ve got some vibration under acceleration with no loss of power and seems to be gone once the desired speed is reached. The jet pump was just rebuilt and wear ring is new. I inspected the impeller for any debris stuck in there when I pulled the boat out of the water, but did not see any anything.
It vibrates worse under throttle over 5000 rpms when the boat is out of the water. My next thought is removing the jet pump and inspecting everything further. Maybe something is tangled on the spline that cannot be seen with the pump on the boat.
This issue started on the first ride of the season after jet pump rebuild.
Does anyone have any ideas?
