Foobar
- Charleston, SC
- FSH Sport
I replaced the lanyard engine kill switch with something a bit more modern.
Hey foobar
You still happy with your electronic mob cut off? Im gonna install same.
I found the old model for $100 in eBay.
@F.M. you can wire it with the existing kill switches still in the link or exclude them. If you keep them in the loop, you would need to put a kill switch cable on the switch at all times on a key chain or something. I wired mine without the stock kill switch. It was easier and unnecessary with the MOB+. Make sure you get the dual engine harness with the MOB+ if you have more than one engine.
FWIW, this is money well spent. I now use my safety lanyard (the MOB+) at all times. Mostly because the engines will not start without it unless you press the manual override button.
I meant to ask you, @Foobar, how much do you like the MOB.
I'm curious if there is a manual "override" to stop engines manually while in the boat. For example, if you were thrown out of your seat but did not fall overboard/out, that kind of stuff.
Hypothetically speaking.
Thanks for getting back to me. I asked the question because while I was fishing, my dog decided it was time for me to jump in. Using the remote while in the water wasn't easy. Made me think I should have a better system. At least it's waterproof.
I talked with Minn Kota about trying to tie into their system, and they didn't recommend that, but rather I use a relay to break the battery connection. I think I found a relay that will work, but it's not cheap.
http://www.flamingriver.com/index.php/products/c0015/automaticbatterydisconnect/FR1051
Thank you.Yes, you push the button on the fob on your wrist. If the engines are running, it shuts them down. I show an example in the video above.
