suke
- Holly Springs, NC
- X
Saw someone post this on FB last night. Figured some of you are pretty tapped into the development of all things Yamaha. Anyone know more info about this? Appears you'd have to rip out your hard tanks. To be sure there's no way to get the connext system to fill up 1700 lbs of rear ballast bags. Even in the engineering menu I've adjusted my center locker bag to the max and it still doesn't fill it all the way tight. This would push the total ballast weight over 2k lbs and could actually keep me in a yamaha boat. The wake booster is a non issue to install. The transom fatsac is what takes a really long time. I'd love to fill the ballasts while idling out to the surf spot. I might even consider a 222 if I could get a decent push button surf wave out of it. Granted next boat will have to be bigger and 100k for a jet boat just doesn't make sense to me........yet.
WakeMAKERS 2017-2022 Yamaha 212X Rear Factory Upgrade
WakeMAKERS exclusive Factory Ballast Upgrade Kits are built and designed to unleash the full potential of your Yamaha 212X's wake. It takes more than just the stock ballast to achieve the wake you've always wanted. You want an improved wake because it is proven to make for a more enjoyable...
www.wakemakers.com
WakeMAKERS 2007-2016 Yamaha 212X Rear Factory Upgrade
WakeMAKERS exclusive Factory Ballast Upgrade Kits are built and designed to unleash the full potential of your Yamaha 121X's wake. It takes more than just the stock ballast to achieve the wake you've always wanted. You want an improved wake because it is proven to make for a more enjoyable...
www.wakemakers.com
