Wakesurfing behind Glastron GTS187
Todd Chandler
Glastron
GTS
Has anyone ever tried 2 wake wedges on a single drive jet boat?
-one wedge sprays up to much behind my Glastron with fat sacs
- works fine with boat evened out with wake
- doesn't work as good when you put more weight on one side
-would be nice to know if it would work before I go buy another ronix wedge
Ronix wedge is used for delayed convergence, it should be mounted only on the side opposite to the surf side. But - if that side lifts (up) out of water too much when you list the boat with ballast, that could be the problem the problem with the spray. May need to ballast both sides (and one more than the other for listing the boat) to push the whole stern in to submerge the wedge.
