Warm water from Bilge.....on the water need some help.
2kwik4u
Buffalo, NY
For starters, to get some visibility quickly.....@HELP
Now, we're on the water and have an issue. Just launched about 30min ago. Did a 20min cruise and stopped to swim. Bilge immediately kicked on and started pumping hot water. Immediately open engine compartment, and don't see any major leaks. There is a section of fiberglass that has a ton of water droplets like It's been sprayed. It's also just forward of the manifold and under the oil filter.
What can I check before I fire the engine back up? Obvious check for water in the oil. Anything else?
I assume I don't need a tow back into the ramp at this point. How can I be sure it's OK to drive until I can figure out what it is.
We'll be anchored for a few hours and since it's not actively leaking I think we're OK to hang out for the time being.
Anyone have any thoughts?
After the engine cooled down I start at the hose coming in to the oil filter and work my way back through the clamps and hoses that go around and back of the engine. Here's a drawing if you need. The water may be hot from impacting the manifold. Wouldn't start her up until I checked hoses and clamps, they tend to rust and/or leak. Good luck!
Here's a pic of the engine bay.
Water on right hand side below exhaust manifold/oil cooler.
Just checked the oil. Aside from being hot as dammit, it looks fresh and no signs of water intrusion.
You likely have a broken hose clamp under the cleanout tray. I would take the time to open that up and investegate before trying to head home.
Start the engine with the hatch open and look for any water spraying
You mean the screwed down piece under the hatch that accesses the cleanout plugs?
I have a screwdriver with me, as well as pliers, but don't have another clamp. Might have some zip-ties.
Best I can see with it hot, they're all present and accounted for. Will give it an hour or two to cool off and will feel around.
Overall update.
Have a friend here with another boat, and have ropes on board to get a tow back in. Would prefer to not do that, but will if I need to.
Going to go float in the water and drink a frost beverage to calm my nerves. Will check back shortly.
don't you have a manhole access cover near the cleanout plugs? if you do, unscrew that to see your water boxes/exhaust hoses,
when your ready to test again, keep the engine open and idle around the cove with the hatch open and then just bump the throttles to see if you see any water, otherwise I would drive back to the ramp with the engine hatch open to monitor the water level, as long as it wasn't massively flooding I'd think you'd be ok to get back to the ramp,
especially if your other passengers could ride on your friends boat,
you don't have to take all the small screws out, it should be two circular covers about 4-6 inches that unscrew,
look at this parts schematic
Could have been water from rain running into the Back and engine compartment. Warm from sitting in boat, after it came off plane it collected in bilge by pump and got pumped out. Needs 2” to switch on some pumps. Or wire connection just made contact if it was corroded.
Well...... we're home.
Pulled the manhole things out of the cleanout tray and felt around. Nothing obviously broken or missing. All the hose clamps attached to the exhaust are in tact and appear to be tight.
We idled around the cove a bit and couldn't see water coming in anywhere. Had a friend holding the switch while I looked in the manholes while under way. No water coming in that we could see.
Took a quick ride outside the no wake zone and got up to about 30mph and 6500 rpm. No problems once off plane or while continuing to idle around cove.
Ran it at WOT back to the ramp. Again no problems when coming off plane.
Boat was reasonably "dry' when I pulled the plugs on the ramp maybe 1/2gal of water out of either plug.
Did find this in the Bilge. Never seen it before in there, doesn't mean it's new just that I haven't seen it before. Anyone know what it is?
Spent some time in the garage tonight. I can't find a missing or loose clamp anywhere. I checked every clamp I could reach from the pump to the pee hole and couldn't find anything that looks or feels awry.
Any chance it only leaks at WOT where pressure is highest in the system? If so how could I check that?
Do you store it outside,
Could rain have entered and then been warmed by exhaust ?
Did you have bilge on when you unloaded from trailer?
Took the boat out again yesterday. Same symptoms. Run around for 15-20min between 6k and 7.5k rpm. When I finally stop, I get SIGNIFICANT water from the bilge.
This time it wasn't HOT though, just like warm. Makes me think it's trapped water at some level and just getting warm from sitting.
Boat lives in the garage, so it's not rain water in there. I'm going to try and get the front lifted as high as I can after the next outing and see where that lands me. Driveway is pretty steep and we always let it sit for awhile nose up after each outing.
I'm a touch OCD about keeping water out of the boat in general. This one is bugging me.
Definitely need to figure it out
Maybe let it just float to see if you get any water, that would lead you to hull fitting
We flo
We floated for about 2hrs yesterday between watersports and more cruising. No consistent bilge pump activity over that time.
I suspect one of the cooling water fittings is leaking under high RPM generated water pressure. Gonna have to tape a GoPro and light under the engine hatch and go for a drive.
Had the hatch open at WOT yesterday. Boy is it loud....like WOW....anyway, no visible streams of water from engine that I could see. Didn't spend a ton of time in there though as putting my head next to an engine at 7,500rpm didn't feel overly safe.
