JESFromASC
- Anderson SC
- SX
I'll do my best to keep this short but ---
2021 SX 195 kept at a marina in a COVERED slip.
Yes, maybe the roof leaks a little, like a drip here and there, maybe.
Yes, a foot of the swim platform is exposed and under the roof edge.
But why is my battery hold area ALWAYS soaking, wringing wet?
Where on Earth can that water be getting in?
I just sucked about 1.5 gallons of water out of the carpeting!
And speaking of such things:
I have it out of the water and getting ready for winter storage.
With the main drain plugs OUT and the gear locker DRY when the boat is tipped up as far as the jack allows I sucked out literally a few gallons of water from a low spot near and just ahead of the drain plug on the right facing ahead. This is through the white access panel to the right of the pump well clean out under the rear access cover.
Does this boat have a hidden ballast tank or something?
Thoughts?
Thanks
Thoughts?
Thanks
