eggwhite93
- Crestview Fl
- AR192
2015 AR192. I lost power (10 MPH max speed) last time I had my boat out, luckily I was near the slip. When I tied the boat up and was cleaning up, I opened the seat to cut off the battery and that compartment was half full of water. I opened the engine compartment and the water was almost to the top of the engine. I turns on the bilge pump and waited for it to drain. Once the bilge was mostly drained, I started the engine and water is spraying into the bilge from the aft of the engine quite quickly and there is a bit of a clunking noise coming from the area. I turn off the engine and no more water coming in. I had to let it sit over night as I did not have the trailer or tow vehicle with me. I came back the next day (today) to recover the boat and no new water in the bilge. So it is only taking on water when the engine is running. I’m sure there is something wrong in the prop shaft area but I am hoping someone has a place/direction for me to start my troubleshooting.
Thanks in advance for any guidance.
