2kwik4u
- Buffalo, NY
A few years ago I got into a pretty good debate with some folks on here about how much water did or did not wash over the rear swim platform. Some were convinced that it was SOAKED, and some were convinced that it was DRY. I remember where I stood, but it doesn't matter now (arguably didn't matter then either). I was also fighting a water intrusion problem at the time, as well as having some curiosityas to WHY the rear access plug ALWAYS has water over it. There were many debates about this as well, most centered around water "leaking" past the seals and filling that tube.
I decided to make some videos to "figure out WTF is going on back there". So, I went out on the Ohio river near Westport KY to do some testing early one morning. I had a family member with me to run the camera in a few shots. The other shots were using a RAM X-Grip/suction cup combo mount to view the rear platform at speed. All the videos were taken using the Torque Pro App on a Samsung Galaxy Note 4. The torque app allowed me to take a video with GPS data overlayed, and really helps solidify what is happening.
Here's a breakdown on the videos:
Water was calm, and loading was light for all of these videos. No ballast, no cooler, ~300lbs of people and "normal" gear (anchor, vests, tube, etc). Boat is a 2017 AR190.
Video No. 1
Shot from inside the boat being held by a person.
Ran boat to "surf speed" then slammed throttles in reverse for "sudden stop"
Video No. 2
Ran boat to "full speed" then slammed throttles in reverse for "sudden stop"
Video No. 3
Shot from RAM Mount watching rear cleanout tray
Video No. 4
AR190 Swim Platform Washover Testing - A Youtube Playlist - FYI, the videos are "out of order" in the playlist. Pay attention to the title to match up the events with the descriptions above. Also, the HD versions are still processing on Youtube, the first one is done, but the rest are still working. Hopefully the HD versions are up soon.
Results/Conclusions
Water DOES NOT wash over the upper platform in a lightly loaded application. There is a "little" bit of a washover in video No. 4, but it's relatively minor, and I think would have "splashed back" had the lid been closed. Hard to say really.
Water DOES NOT leak past the cleanout port seals
Water DOES backflow from the waterline to the cleanout tray via the drain line
Your mileage may vary, and this certainly doesn't cover a boat setup for surfing with tons of ballast. Also doesn't account for heavy waves/traffic that would create a TON of backlflow from that drain. For me, this solidified the premise that the water over the cleanout plug is harmless and not causing any performance issues.
Please discuss, as I've had these videos since July 2018, and just now "found them" and took the time to post them. I'm curious if anyone else has any other videos to add, and what they think of these.
Video No. 1
Video No. 2
Video No. 3
Video No. 4
Results/Conclusions
