- Royal, AR
- SX
Recently we added a SSL Certificate to the forum and are using it for the SWAG order forms. The [USERGROUP=3]@Administrative[/USERGROUP] crew has been testing using the entire site via HTTPS encryption for the last ten days. We will transition the entire forum to using HTTPS on the 26th. This move may require you to re-login but that should be the only change to your usage of the forum.
Some of benefits of the transition will be;
Privacy - your communications with the forum will be encrypted from the computer or mobile device you are using all the way to our server.
Security - your username and password will be encrypted when they are exchanged.
Comfort for new registrants - the registration form will be encrypted providing the same level of comfort that they would have shopping at an online retailer.
Search engine ranking - Google ranks HTTPS content above unencrypted content.
This New York Times Blog Article goes into more detail if you would like to learn more about HTTPS http://open.blogs.nytimes.com/2014/11/13/embracing-https/?_r=0 .
If you would like to try using the forum via HTTPS before the 26th please click this link https://JetBoaters.net . Currently we are experiencing some issues with needing to re-login when switching from HTTPS to HTTP (unencrypted) content. These issues will go away once the entire site is moved to HTTPS.
