Wet and Naughty! LOL Used 210 FSH Deluxe picked up today!
jknapp
FSH Deluxe
I just picked up a 2020 Yamaha FSH 210 Deluxe today. Excited but overwhelmed by the by all the little things that need to be done and the other things that I want to do as upgrades. I feel pretty good about the mechanical, engine/hours, and hull integrity, for my new vessel & trailer after inspection and sea trial. I drove it the 2 hours trip home and stopped several times to make sure everything was copasetic. Will be taking it out tomorrow with my friend who is an experienced captain to practice and get a feel for unloading, handling, loading, etc. Any tips on what to look for would be appreciated?
Being used, there are a lot of little things to replace, upgrade, repair, or add. Any thoughts on prioritizing the following. I enjoy fishing but will use more for pleasure cruising in a few months. FYI, I have all my FWC and USCG required safety equipment.
  • Need a trolling motor and full setup with batteries, chargers, etc. No plans to DIY it.
  • Subwoofer, and forward speaker wiring needs repair (was cut so they are just not hooked up right now. DS18 speakers with LED module and DS18 1200w amp. Console and transom speakers work fine)
  • Starboard console rod holder missing and needs replacing
  • Buttons for many of the cushions are corroded from saltwater and very fragile, many won't even snap on
  • x1 bimini top pipe for awning was shear off and will need to be replaced.
  • Need a keel guard
  • Minor cosmetic defects to exterior hull related to dock rash
I am located in Orange County, Florida. Any suggestions on reputable service centers for installation, repair, or regular service would also be appreciated.
Thanks again for any input or advice!
-Joey
Congrats on the new boat!
How many hours are in the engines?
Did you pull the aft bilge hatch and look down inside that compartment? A good place to check for corrosion..
Have a look at the clean out plug seals too.
When was the last time the spark plugs were changed?
  • 170 hours on each engine
  • Bilge hatch was surprisingly very clean and free of corrosion.
  • Previous owner and I had discussion regarding clean out plugs and his practice of removing them to prevent warping and keep appropriately dry or coated with lubricant/Vaseline to maintain them. They looked in good condition to me.
  • Plugs were changed last month when yearly service was performed.
Main/minor issues I found were corrosion of button snaps for most cushions, wiring for subwoofer & bow speakers was cut and no wire present to reconnect, but console and transom swim deck speakers were in working condition. Has 3 batteries, but only 2 seem to be hooked up to anything. Friend on mine and captain taking out tomorrow to run on the water and identify other potential issues.
Good luck on the maiden voyage today!
Pretty low hours on the engines! You’ll need to either check or have the valve lash checked at 200 hours.
Did you test the bilge pump?
What was serviced at the yearly service?
Was it used in Salt or Fresh water?
Are you going to use it in salt or fresh water?
You’re correct in that there are A LOT of little things to do on the boat but many of them will take a small amount of money, the rest is your time.
First thing I’d do is order a service manual if one didn’t come with the boat, let us know if you want to get one and I’ll post the link to where you can purchase it. This will show you how to change the oil in the engines among other things, knowing how to do this will save you hundreds of dollars if not thousands over a couple of years.
If you don’t know whether not the intermediate bearings have been lubricated or not those will need to be checked and or lubricated. These require a very careful hand in lubricating as too much grease can damage them. Again we will help you out here, hopefully these were done at the yearly service. The schedule is annual and or 100 hours.
The cones on the end of the jet pumps will need to be pulled to check for water intrusion and repacked with grease. Just talked with Yamaha the other day to confirm how much grease goes in them, they should be filled, I’m going to make a separate post about that.
Good deal on the spark plugs….a lot of us put a very thin layer of anti seize on the spark plug threads to assure they do not get stuck.
Also good deal on the clean out plugs! Some folks use pool O ring lube, others like myself use silicone spray.
Is the engine bay / bilge really clean? If not you can put in the main drain plug and dump in 10 gallons of hot water with Dawn dish soap mixed in and trailer the boat around for a half hour then dump it, rinse with hot water twice in the same way, tow it around for 10-15 minutes. Leave the engine bay and other compartments open for a day to let it all dry out. You will need to pull the fuses in the fuse holders in the battery compartments or disconnect the negatives from the batteries to keep the bilge pump from coming on.
Next will be drying up the Bilge. There’s a lot of places where water can get into the boat.
-The first is the clean out tray, super easy to fix this by carefully putting down a thin layer around the edge of the tray where it meets the boat, don’t put it under the tray as this will glue the tray to the boat.
-Next will be a mechanical access hatch riser from jet boat pilot.
-Remove the cup holders in the storage pods and put sealant under them and re install, these are not sealed from factory and when water pools on top of the storage pod water will rain down onto your stuff. Remove the two front most cup holders in the bow and plug the drains as when water gets into them they drain straight into the port and starboard storage areas, seal them up when reinstalling. I also recommend sealing up all the cup holders. The cup holders on the transom drain straight into the bilge as well, you can seal these up the same way you sealed up the two in the bow, you can connect drains to these as well and route them out onto the swim step but the easiest is just to plug the drains and seal them onto the transom. I recommend Three Bond 1211 silicone sealer, its not cheap but for the cup holders as it stays very flexible. You will need to put some clear silicone on the chrome trim rings that hide the hold down screws to keep them from disappearing. You will want to put small hose clamps on the cup holder drains to make sure those drain lines stay in place.
-Rod holders, the two up front on top of the storage pods have drains that go over board, the rest do not and will drain straight into the bilge and aft storage compartments next to the helm seat. You can get universal rod holder drains from T-H marine then route the drains onto the deck of the boat where it will go out the main deck drain. Also, I’d remove each rod holder and seal it to the cap rail with UV stable 3M 4200. I installed additional deck drains and tied in the rod and cup holder drains in the aft area to those drains.. if I had it to do over again I would do it like the post linked below and just dump them onto the deck and let the water go out the deck drain, the way I did it was a pita, it works but was hard.
The next area where water gets in is the anchor locker drain, @drewkaree made an excellent post about this and my post is #118 & #125.
Replaced my anchor locker drain fitting due to leaks
I do not use my anchor very much so I keep that plug shown in post #125 in place to keep water from coming in whist on the water. You will need to pull this plug once in a while to make sure no water has accumulated there, if you’ve washed the boat or it has rained on it without a cover on it.
At some point you are going to want to replace the OEM plastic scuppers. There have been a few folks that had catastrophic failures that lead to a bad day on the water, on all the boats not just the FSH models. Sometimes these fittings will just crack and let in random amounts of water that will drive you nuts trying to figure out where the water is coming from. These are a PITA to install but well worth it.
Check your live well fittings for snugness. When I installed my electric raw water wash down pump I knocked one loose and it took me a while to figure that out. Also there is a little black fitting on the bulwarks of the transom that is the air inlet for the aerator, there is small black hose that goes from this fitting down onto the suction side of the aerator fitting in the live well, some folks have had this hose come off and a small stream of water will go into the bilge when ever the live well is full. You can access this by removing the starboard transom cup holder and reach down in there, you will have to feel around a bit to find it, take your time and you will figure it out. You will either discover the little black hose is connected or you will feel the small nipple on the fitting that is attached to the live well.
All that seems like a lot, but just like trying to eat an elephant, you take one bite at a time. The end result will be a dry bilge. Most of the time I do not get a drop out of the drain plug at the end of the day, sometimes I might get a tiny bit if I use the raw water wash down a lot and I suspect some water gets in around hatch seals from the high pressure stream of water, and or gets in through jump seat seat back slots. And you will have a good time doing all of these projects and create a great deal of pride in ownership!
For working on your boats engines you can make one of these on the cheap.
As far as the trolling motor goes, there is an OEM trolling motor mount that is intended to be mounted on the port bow area, this area is reinforced from the factory. This OEM mount does flex and some have built there own out of thicker material, I’m still using the OEM mount with my 112# thrust Rip Tide Ulterra, it is on the list to get upgraded but that has not happened yet. I also recommend the heavy duty Minnkota quick disconnect electrical plug for the trolling motor, which ever one you get, it is very burly. This brings us to what type of MFD / Fish finder you have, do you have one? Or are you going to get one. Which ever one you have or are going to get, you need to look at the compatibility of the trolling motor and the MFD. I have a Solix MFD and a Rip Tide Ulterra trolling motor and they work seamlessly together, Garmins from what I understand work well with their Kracken brand of trolling motors, Lowarance and Simrad have a brand new Recon trolling motors that work well with theirs. I think but am not sure about Motor Guide trolling motors working with Garmins, pretty sure those work with the Simrad units that come on the late model 222, 252 and 255 FSH boats.
Next is how are you going to power the trolling motor? With lead acid or lithium batteries? The lead acid are the best if you do not have the dough for the LFP batteries. The brushless trolling motors will work without limitations with the lfp batteries, the brush type are limited to 85% of max output due to the LFP batteries higher energy delivery potential at high prop speeds. However, if you decide to go with LFP batteries, my recommendation is to not go with the off brand inexpensive ones, I only can recommend Battle Born as my highest, ReLion as second choice and Dakota Lithium as my third choice, I’ve seen enough of the problems with the inexpensive LFP batteries to recommend shying away from them. AGM batteries are nice as they gas very little and are very clean but do not have the capacity of flooded lead acid batteries, its close but the FLA batteries usually have more Ah’s / KWh of storage. Here is a link to my journey with LFP batteries. Conversion to LiFePo batteries
On board charger… if your boat did not come with one, then you need to get one for your boat. NOCO is the most popular brand here, Pro Mariner and Minnkota are others, but I have switched over to Victron Energy IP 67 chargers mainly for their 25A output for my LFP batteries, LFP batteries do not need 25A of charging power but they can easily take more than 25A, but the 25A charger cut my charging time from 12 hours to 3. Which ever charger you get, just make sure it is 10A per battery. Then we can talk about modifying your dvsr so that each battery charges independently which is best for your house battery. Just be sure the battery chargers are set for the chemistry of the batteries you have. Our boats have pretty limited charging power, roughly 13A’s per engine above 3500 rpm, and about 6-7 at idle. If you are going to keep the batteries that came with the boat, be sure and put a good charge on them as soon as you can and check the specific gravity if they are flooded lead acid batteries.
You need to sort out why those speakers wires were cut, did the owner not tell you the reason? Sounds like there was some additional stereo equipment that was removed and was powered by that third battery? Speaking of which if it is not connected to anything get it out of the boat..no sense in carrying around all that weight for no reason.
For your snap issues..
I hope you enjoyed the maiden voyage today! You’ve started on a great and fun journey! Your boat has tons of potential for all kinds of fun at a pretty low cost. The TR-1 engines are thrifty on fuel and our boats are simple and not too expensive to maintain.
Hey @jknapp , I know it looks like @FSH 210 Sport just gave you a graduate-level text book to study from on your first day of class, but when you dig into all of that great stuff he gave you, you'll see it's all easy and straightforward and doesn't all have to be done on day one. He's a fantastic resource.
Congrats on boat!
I'm not a salty guy so not much help here...
Can't respond to all of these things, but will keep it as a Yamaha Jet Boat "Hack Sheet"
-Bilge pump works fine
-was used primarily in salt water, I will primarily in fresh water use with occasional trips in salt... 2-3 a year maybe
- As far as yearly service I didn't get an itemized list, but it was serviced by cycle springs out of Clearwater I think. They did use antiseize on the sparkplugs
-Engine compartment is very clean and I thought that was interesting as it looked barely used, but someone cleaned it frequently.
- I have the Simrad GO XSE standard. Still playing around with it, but the intended plan was to purchase the MK Riptide Terrova 36v 112lb thrust trolling motor and have it professionally installed, but open to suggestions if compatibility is an issue (planning on having it professionally installed regardless).
- I think the investment into Li is worth it. May not even have to buy a new one before I upgrade.
Maiden voyage went fine. Minor issues with the clean out plug for starboard side was really difficult to get secured, but a little elbow grease took care of that. Removed post voyage, and plan to replace in the future.
Throttles are not perfectly in sync and somewhat "touchy" in terms of get up and go or going slow. Think it was more user error, but the throttle cables could probably use some adjusting.
Thats all I can respond to for now. Thanks again!
Glad to hear maiden voyage went well!
Minnkota will not interface with the Simrad, looks like the Recon will be your motor if you do want to change MFD’s.
As far as the CO plugs, get a tube of o-ring grease for swimming pools. I never had any issues while using this. https://www.amazon.com/Hayward-SPX0...cphy=1027413&hvtargid=pla-2281435179538&psc=1
And on replacing the snap buttons...if the stud is ok, you can replace the cap easily by drilling out the mushroomed material on the backside. This tool is pricey, but is high quality and what I use. Pres-N-Snap® Installation Tool
You could counter the initial price by doing snap repairs for others in the Central Florida area, you are not the only one with this issue.
Update on progress thus far. Been a little busy with school and work along with the unseasonably cold weather here in FL.
Almost all the button snaps for the cushions were in need of replacement. Replacing them was pretty simple. Got this from amazon and seemed to work quite well.
I spent a couple of hours or so giving everything a good washdown, cleaning the vinyl, adding my registration sticker, new trailer tag. I had to clean out the bow port side storage in prep for trolling motor install next week. I'm paying someone to install, but here's a quick list of items, and not all inclusive.
Mi Kota Riptide Terrova 60" 112lbs thrust 36v
MK Quick Release Bracket
Yamaha Offset mount
MK Stabilizer Kit
Plug and Receptacle
EPOCH 36v LiFePO4 100Ah Battery
EPOCH Charger
MK On-Board Charger
Circuit Breaker
Started making notes of items that need to be replaced or upgraded. I already purchased a new raw water hose and nozzle as the original was so corroded from the saltwater that it was unusable. Other items I noted in no specific order.
  • Both helm rod holders need to be replaced/upgraded
  • starboard side bimini top frame locking pipe needs replaced
  • Bimini canvas will need replacement in the future. No rips or tears, just starting to show signs of being faded. May be able to restore?
  • All cup/rod holder drains either need sealing, or zip ties holding drain tubing need to be replaced with hose clamps
  • Still need to do more in depth examination of each drain. Bilge works as intended but may need to ensure that they are all clear of any obstructions. Not sure how fast they should drain, but seems a slower than it should be?
  • bow hull storage compartment latch needs replacement
  • Transom deck latch needs replacement
  • a couple of the passenger cushions look to have some very minor spots of rust staining, but I am fairly confident that I can get them clean.
  • Starboard side Yamaha graphic last "A" needs to be replaced.
  • Want not need new registration lettering for both sides
  • Engine throttle cables need some slight adjustment, but nothing in need of imminent investigation
  • Need more ballast load on the starboard side. For now, full live well, and cooler seem to do the trick and will adjust once trolling motor installed.
  • A few random screws need to be screwed in or tightened.
  • Of course the helm subwoofer and bow speakers wiring needs to be addressed in the future, but seems very minor and the helm, swim deck, and under helm seat speakers work. Under helm seat speakers may need to be replaced in the future
  • Also need to test the RGB speaker lights to ensure RGB module working, but not using a lot at night so not super important
  • Dock rash and some scuffs in a few places, but can address in the future along with scheduled maintenance
  • Helm inspection cover assembly will need replacing as the zipper is seized
  • Helm rocker switches need to be labeled
  • third battery in main compartment needs to be investigated and if not hooked up to anything can be removed
  • I have a 45qt RTIC cooler for under the helm seat and need a securement device. bungees? or something else.
  • Already purchased some quality dock lines
  • Will need some shallow water anchor poles and ropes or rod placed anchor pole holders. Just need to determine if all rod holders are 30 degree
Haven't forgot about @FSH 210 Sport bible near the beginning of this thread, but making progress. :)
