johhnyboat
- Ocean City, MD
- Limited S
I have some questions and observations...
I have a 2016 242 limited S that is new to me. I notice that this boat takes on a lot of water and in some places has pretty poor design. Water get's into the bilge pretty easily through the cleanout hatch and the cup holders, ESPECIALLY the cupholders on the transom. This USUALLY would not be a problem. In most boats that's what happens, but also in most boats the bilge pump sits at the lowest point and easily pumps the water out of the boat. I have installed a second bilge pump in the ACTUAL bilge and when I tested you have to dump several gallons (like 15) to get it to engage. That IMHO is waay to much water in this boat before it pumps out anything. if this is the case, why not have the cupholders drain to a scupper valve??? I haven't removed the one's in the cockpit, do they?
Here are things that I have done:
Is there anything else that anyone has done to reduce the amount of water that get's in the boat?
Thanks!
- Second bilge pumps
- Replaced cup holders in transom with (NON DRAINING).
- Replaced anchor locker thru hull
- Caulked around the cleanout tray
Thanks!
