Wet sounds 3 some
Meetball
X
I am looking at going all out on stereo this year, I found a wetsounds 3some package with a syn-dx6 package but I'm wondering about the specs. They say this amp was designed to run this setup but after looking at everything it isnt adding up. I am hoping someone can chime in on the power per channels being over what the speakers are rated for.
This bundle includes a pair of the Wet Sounds black REV10 swivel clamp tower speakers, and a black REV410 swivel clamp dual 10" & HLCD tweeter tower speaker & SYN-DX 6 6-Channel amplifier designed specifically to run this configuration of speakers.
Rev 10 Specs Impedance: 4 ohms RMS Watts: 300 PEAK Watts: 600 Mid Bass: Size & Weight Front-Back: 13" (330.20mm) Hang Height 11 9/16" (293.68mm) Width: 10 5/8" (269.87mm) Hang Weight: 14.8 pounds / 6.71 kg each
REV410B-SC Specs Impedance: 4 ohms RMS Watts: 400 PEAK Watts: 800 Mid Bass: Dual 10 inch HLCD Tower Speakers High Frequency: Separate Titanium Diaphragm High Output Horn Loaded Compression Driver Size & Weight Hang Height 11 inches (279.40 mm) Height: 11 inches (279.40 mm) Width: 28.5 inches (729.90 mm) Depth: 20.5 inches (520.70 mm) Clamp: Clamp center to center: 9.25 inches (234.95 mm) Hang Weight: 36.2 pounds
SYN-DX6 amplifiers use superior performance circuitry by utilizing Class D Power Supplies.
Stereo @ 4 Ohms (CH1-4) 125 x 4 watts RMS >1.0% THD Stereo @ 2 Ohms (CH1-4) 200 x 4 watts RMS >1.0% THD Mono @ 4 Ohms (CH1-4) 400 x 2 watts RMS >1.0% THD
Stereo @ 4 Ohms (CH5-6) 150 x 2 watts RMS >1.0% THD Stereo @ 2 Ohms (CH5-6) 300 x 2 watts RMS >1.0% THD Mono @ 4 Ohms (CH5-6) 600 x 1 watts RMS >1.0% THD
With all of this info I am reading each rev 10 will get 400 watts and the 410 will get 600? I am hoping someone can chime in with if this setup is correct.
I have the same setup, the syn dx6 when bridged into 3 channels (one channel for each speaker), puts out an amazing 585w per channel into each enclosure. Also, Wetsounds is VERY conservative with their power handling ratings. The 3some can handle just about everything that amp can give them
