I_squared_r
- Medellín, Colombia
- 242 Limited S E-Series
Wetsounds HTX-6DSP-OE11180467 Amplifier OEM from 2019 Yamaha 242 Limited Jetboat $150 shipped in continental US.
Removed from my boat with 65 hours on it. Amplifier is in working condition, but was removed for upgrades. This is the same amplifier as the Wetsounds HTX-6, but this is the DSP model which is the OEM model from Yamaha boats. So there aren't knobs on the amplifier to adjust gain, input sensitivity etc. There are no RCA's, I think that the input to the amplifier are high level speaker inputs. There are 4 speaker channels and 1 subwoofer channel. The subwoofer is known to be underpowered, but maybe you can remove the Yamaha tune through the DSP connector, or you can use a line driver to increase subwoofer output. I had a JL amp from my other boat with the subwoofer remote so I swapped it.
There is a missing screw on the cover. I'm sure you can find it at a hardware store or just ignore it. It doesn't impact functionality.
