stpetesearayderf16
- SeaRay
- Other
As mentioned elsewhere, it's from the factory speed sensor - just ignore it and connect +/- wires for the GPS speedo and you should be good to go.I have this right now, I just mounted it in my OEM speedo location. Just not 100% on the integration to the oem wiring. There is a "Gauge data" wire coming off the back of it, not sure what that does.
For the price, it would be worth taking a chance. My MFD went out on my Kawasaki jet ski. At the time, It was $700 just for the OEM replacement.
To @stpetesearayderf16 I agree...Yamaha doesn't use standard NMEA 2k for their systems so you'll probably just get speedo functions.Unlikely you will get RPMs on this thing from a Yamaha...I don't see any info on what it does use (NEMA 2000?). So it would work as a GPS speedo....since it says it comes with the GPS puck.... for the rest....who knows (but Yamahas are a proprietary system...so I can nearly guarantee it won't work for RPMs on a Yamaha out of the box).
