What Home Improvement have you done...
GiddYupJoe
Beavercreek, Ohio
Boatless
NA
X
NA
I always find it interesting what projects folks are working on around the house while your not out boating. Figured I would start it up. I’m sure there are some crafty boaters out there... what are you working on? Here is my latest (still have to finish crown). After and before.
77495422-596A-4FDB-B550-8C652BF1BF39.jpeg71BA1C46-9902-4931-8B3F-284428707E55.jpeg2A2DD15A-1449-4D8B-AA65-8BCB227F9478.jpeg49CA2E79-50F4-4503-AA1C-CF0EC1FC0D9A.jpegCF39C5FC-EEF4-4797-9A60-B1F88A390F84.jpeg08B1D1B6-A82D-4EE0-9647-672A4F6EA163.jpeg
New shower. Its internal dimensions are 3'x 7'20200830_152202.jpg travertine floors.
@GiddYupJoe , what year was the original kitchen from the before photos put in?
Did you put a door on it? Curious as I wondered if it would be colder in the shower without a door. Looks amazing by the way!!!
I wish I had these skills....want to put a shower in the 3rd floor....got a quote for 15k to redo it.
No door. It heats up ok , with all the shower heads.
House was built in 93. Nothing updated. I opened a can of worms when I started ripping out the oak trim... now I am continuing on through the house. Going to keep the solid oak doors and paint them (eventually). I would prefer a different style but damn... don’t find solid doors like that without some $$$
@djetok What is the length and width, inner, on the shower. I thought about doing something similar just debating on if I have enough room.
Bathroom I redid in the basement of my last house. Said I would never do that marble tile again... year later... it’s the backsplash in the kitchen!
Wow that sounds high, but 3rd floor though. It would suck going up and down the stairs, making sure there would never be leaks. I would write a check.
7 foot long and 3 foot wide on the inner. The length used was previously a large walkin shower, a full door 30" door toiletry closet, and a soaker tub. The length is just the right length , the shower does not splash water out. It possibly could be a foot shorter though.
@djetok Thanks. I don't have that width, I am at 37.5" on the outer dimension, so by the time I do 3.5" for wall and say another 1" for backer board and tile, I believe it would be too narrow in width. I do have 7' in length. Probably will just tile it out and put glass doors on it. Sucks, cause I like what you did there a lot.
Measured it for you
I was going to guess mid 90s. My wife said 80s but the counter tops and island dated it a little newer, in my mind. The use of red oak and cathedral style raised panel doors was a leftover style element from the 80s, though. So we had a bet going on the year. I guessed 1995.
Either way, looks much better now with the shaker style cabinet doors and door moulding. Is that quartz countertops?
It’s quartz. Specifically Calcutta Massa. Supposedly since it’s all man made, it’s a common name.
And I appreciate your eye for the design!
Thank you. As far as the solid wood doors go, did you think about just making your own doors? They're not super hard to do, and you seem fairly handy. Probably cost less than 200 bucks apiece unless you want to use some exotic species.
In middle of 400 sq ft addition and 2200 of additional fixer/flip while living in it. Will never again.
Nothing huge, but my wife just redid our laundry room. Did the faux brick with joint compound, it looks badass thought
