McMark,
Have you been to Dahn Tahn on the Mon? Abaht how far till yinz guys get to Picksberg? I grew up in Trafford! Just up the crick from Turtle Crick! Was Kennywood open when you went past? (did you look down? LOL)
As others have said, it's basically oil & filter & spark plug changes annually. Although you can likely get away with not changing your plugs annually, these engines can be finicky when it comes to tired spark plugs. I figure changing the plugs annually keeps me from having to waste an hour doing it when I'm on the water when I'd rather be enjoying the boat.
For cleaning, lots of us use Boat Bling Products: Hot Sauce and Conditioning Sauce for the seats. When the boat comes out of the water, spend a few moments to spray it with Boat Bling and wipe and it'll look good going down the road.
Are there any consequences if an engine flush is not done between lake outings? I understand the lake water is not clean fresh water, but is also not salty.
It’s pretty rare to flush after being in a lake as the reason for flushing is to remove salt deposits from the engines. I suppose if you’re in really muddy water you could flush but again that’d be an option. I boat in lakes and the only time I flush is when I’m out in the California delta where the water can be brackish (4 foot tidal surge where I was).
Without flush, does the engine water ran out during boat retrieval and towing , or does it really stay in the engine until the next boating?
(We typically boat in some lake, so I'm not worried about cross xfer, just wondering if it eventually gravity drains on own?)?
