What size drain plug ?
JBRyan
NE AL
What size drain plug does the 07/08 year SX230 take? I took it to be serviced and they lost the plug. I also can’t get my clean out plugs back in.
I put boat in after getting it back and engine compartment started filling with water
Ouch. It should take a standard half inch drain plug you can get at Walmart. The replacement Yamaha plugs are pretty cheep too. I ordered 4 the last time I ordered because they also fit in the lower ski lockers.
My local Walmart only sells 3/4 and 1 inch so ordered off amazon
I have ordered every drain plug on this picture. None fit. I know the lockers and each have one thats the same, as well as two in the engine compartment. all but one is missing??
