? What type of seal for engine compartment noise reduction?
ReggieCFL
Central Florida
AR195
I’m finally ready to tackle noise reduction and thought I saw a post with a specific weather trip recommended for the engine compartment that would not interfere with it closing properly, but I can’t find it now. Does anyone have a recommendation on the best weather strip product to seal the engine hatch to reduce noise? Thanks in advance!
search YT for Jeff's Jetboat he has video on pipe insulation.
@swatski posted about good results with a garage door gasket.
I’ve had the same one sitting in my garage for a year and haven’t put it on so can’t comment on how well it works.
Man. I hear you. I started and only did like 3 feet. Got busy and never finished it
Has anyone tried the above method of pipe insulation on the 19’ boats and had good success?
I started with pipe insulation and it worked well for the first season but compressed and didn’t decompress during the first off season. I ended up replacing it with “D” shaped 5/5” x 3/8” (20seal from McMaster Carr. I don’t recall the thickness but glad I went with the 3m adhesive backed variant.
I will probably pick up the insulation this weekend. Don't know if I'll have time to install it.
Can you find the invoice for what you bought? Going to put this on my list of to dos, and want to get the best width and weight. I can see this stuff working FAR better than pipe insulation - that approach seems like using the wrong material just because it was laying around. The foam needs to be strong and bounce back, pipe insulation crushes to easily.
I used the garage door seal and the 3M 90 adhesive releases from it they are not compatible
Did you find anything else that worked?
I bought weatherstrip adhesive that I haven’t tried yet. Hopefully that will stick to it.
when i used the 3m 90 I sprayed both surfaces separate let them tack up then placed sections in. Every part that releases 100% of the 3m is stuck on the gel coat nothing on the door seal. Maybe it has some type of release agent so the gasket doesnt stick to the garage floor. Its on but not good and needs repeated applications
No way on the invoice but according to my original post on the subject I got 5/8” x 5/8” material and 3m (good stuff) backing. The thickeness you go with will depend on the distance to the bottom of the engine hatch, mine has a lot of aftermarket insulation on it so i must have gone thinner. Using pipe insulation as a guide is not a bad idea. Buy different sizes and see which will be tight but still allow you to close the compartment. For as little as it cost me it had lasted a long time, over 5 years and counting.
Awesome, that looks like the way to go
