Where to find cockpit and bow cover for 2008 SX210
terrymargate
Jet Ski
I have a 2008 SX210 and cannot seem to find the cockpit cover and the box cover for this boat.
Have spent ages on google and only fiind 2012 and above.
Not sure if that would fit mine, Im guessing the design has changed a little.
Mine has all the snaps in place on the boat ready so I'd really like to use them and would prefer to buy the bow and cockpit cover as opposed to the mooring cover
Would be very grateful for any pointers in helping to locate this
thanks in advance
OK I found it. MAR210CCVRBK for cockpit and MAR210BCVRBK for bow cover
can anyone tell me if you still require anti pooling poles when using the OWM bow and cokpit cover
thanks
Were you able to find a dealer that can get these? I'm in the same situation and can't find them anywhere. Thanks.
Thanks @Wes514. That is already on my list of options, but the challenge is the boat came with an aftermarket Monster MTK tower installed.
It's a top-mount tower so that cover will require major modification to work leaving the tower up. Tower was installed to lower rearward, but for some reason they ran the nav light wiring up through the front tube with no disconnect. Am planning to cut the wire and install a weather tite connector to allow me to disconnect and see how the tower lays when lowered. am guessing it will be too high in the rear for the factory morning cover to reach over.
First quote for getting a local canvas shop to make a bow and cockpit cover to fit the existing snaps was $1600. Been 20 years since I've owned a boat, but that seems high and I'm not willing to pay that much (yet :)). Am seeking other quotes, but if anyone has a canvas shop in the Seattle area they can recommend, would be greatly appreciated. Thanks!
thanks
Please, please tell me where you found them??? Having the same problem looking for a gray bow cover (not full boat) for my 2008 SX230 It's the version with the notches to fit around hand rails, like the one in this pic, but I'm looking for gray. Where did you find yours???
LOL I am looking for a 2008 SX230 full cover OEM also, and have had no luck! I guess they don't make 'em anymore.
Is a "mooring" cover the cover that came with the boat originally? It seems by definition this would be accurate. Here is the link to what appears to be an OEM.
Funny that my dealer quoted the exact same price, but if I get one here I can get 15% off which is about 100 bucks.....
THE BIG QUESTION IS will a 2009 cover (they don't go back to 2008) fit my 2008? I don't believe the models 200 and 2009 were different. Thanks!
Should be the same, It should fit my 07, without the tower, if we were in the market for one.
Here's one for you. Where can I find the assembly hydrailic arm assembly which is located under the clean out port hatch, which holds the hatch up while you are pulling the plugs out or putting them in? Mine has failed and I can't seem to locate the part.
Part # 23
Thanks, Zip...looks like it might be item 23. At 40 bucks I'll get a storm door assembly and make it work, for 15 bucks!
$40 is pretty steep. Went to my boat a couple of minutes ago to take pictures. This is the strut.
Found on ebay here $12.99, but you may find cheaper shipping costs somewhere else.
Bought an OEM cover from these guys; same one as from Yamaha which cost $741, this was much less expensive. Funny how the sales rep told me "We get the cover from Yamaha and discount the price 25% to you." Good, ol' Momma Yammy, bending over the consumer
Has anyone tried modifying cockpit cover MAR-210CC-SX-NS that is made to fit 2012+ to fit 2006-2010 model years? It appears MAR210CCVRBK & MAR210BCVRBK are no longer available. I'm looking for a better solution for a wet slip than the standard ratcheting cover.
Bumping this to the top. My MAR-210BC-VR-BK has a tare in it. The premium black really held up well. Anyone able to find one?
I'd rather not fix it because who knows how long that will last. I might take it to canvas shop to see what they would charge to make me one.
look at Partzilla, I just purchased the bow cover and Cockpit cover in Charcoal.
I was on partzilla and couldn't find it. Maybe I will search for the grey because the black is showing up on other sites as no longer available.
Your boat is newer, which is why you can probably still get it. My 09 AR210 doesn't show as being stocked anymore.
I was unable to find anything on Partzilla as well. Looking like older Yamaha owners are SOL on cockpit covers.
I actually
I've had the boat since new, so i have a few combinations of covers. I just bought a brand new mooring cover, but like the smaller summer cover. I think I am going to take my bow cover to a place to see what it would cost to fix or make a new one. Its straight forward. I could also ask how much it would cost to replicate.
I actually just talked to a dealer, there aren't even any in the network. SOL is right!!!
