Who likes a good pickle?
zipper
Jetboaters Fleet Admiral 1*
Staff member
Administrator
Northern Vermont Lake Champlain
Boston Whaler
As the title says, who likes a good pickle? I do. You can make crunchy deli style dill/garlic fermented pickles, that I have to say "Nobody can eat just one". It takes about a week to complete the process and are some of the best I have tasted. You will need a fermentation crock, with a water trap/air lock at the lid and you will need to keep water in the trap for the process. We set up a trellis in the greenhouse to grow picklers vertically. Make finding and picking easy. Picking a couple of dozen at a time to fill the crock to just over half full will fill about 2-half gallon Ball jars. Here are a few pics.
Inside the crock we use plates to keep the cucumbers submerged. The second batch is in there, I will taste check this batch in 5 days. It may take a little longer this time because the picklers are bigger, maybe 7 to 9 days before I put them in Jars and in the fridge.
I can't stop eating these, I just ate that whole jar.
We also use the crock to make sauerkraut when the cabbages are big enough. Here is my recipe. You will need 1-3 to 4 gallon crock.
I start with a brine solution. I like 2 1/2 tablespoons of fine sea salt per 1 quart of water. You will need enough of this brine solution to cover the picklers in the crock. I add a pretty good handful of dill fronds/leaves you can substitute a couple of tablespoons of dill seed, but I prefer the fresh plant. Also 1-2 heads of garlic, separate the cloves and smack them, bust them open with the side of a big knife and toss them in. I also add a few grape leaves to keep the pickles crunchy. Put the lid on. Add water to the trap and go boating, well that is how I did it today.
@zipper, look's great. We have been buying some awesome dill pickles (slices) this summer at Wegman's and the family goes through them in a day. I bet the one's you make are better
My wife makes sliced pickles in jars, some shelf stable some not.
These need to be refrigerated once they are removed from the crock. Not the canned with heat/vinegar type that will sit on a shelf in the pantry for months.
Just under six bucks at Costco for a huge jar. Can't eat just one. Best pickles I have ever tasted. Why work when you don't have to!20190827_232122.jpg
Have you tried the devil's spit from famous Dave's? ?
She makes both...but finds the shelf stable ones aren't as crunchy, so she's not being making those as much (which is why my beer fridge is full of pickle jars). Perhaps she needs to try your grape leaf trick (but not sure grape leaves are readily available).
The grape leaves are supposed to keep them crunchy. I can attest to that. Been using wild grape leaves for years and eating crunchy pickles since. They grow all over the place on my property. I steped out the mudroom door and walked about 12' to pick them.
